[gdal-dev] armadillo error with homebrew install of ogr2ogr
Sean Gillies sean at mapbox.com
Wed Nov 11 07:21:06 PST 2020
Hi Paul,
Please be careful about telling people that Conda is a panacea. It's not
true. I maintain several software projects that have conda and conda-forge
packages and I follow several conda-forge repo issue trackers, and I am
here to say that users manage to mess up their conda environments regularly.
Making a stable software distribution is hard. There is no silver bullet.
Conda is not a silver bullet. All distributions that try to provide the
latest versions of software will be semi-flaky. All robust distributions
will have versions that lag a bit. It's like a law of nature.
On Wed, Nov 11, 2020 at 1:51 AM Paul Harwood <runette at gmail.com> wrote:
> Have you thought about just using the Conda Installation? Solves most or
> all of these problems.
> On Tue, 10 Nov 2020 at 17:14, John Muccigrosso <muccigrosso at icloud.com>
> wrote:
>> I've just started getting this error when I try to use ogr2ogr:
>> dyld: Library not loaded:
>> /usr/local/opt/armadillo/lib/libarmadillo.9.dylib
>>   Referenced from: /usr/local/bin/ogr2ogr
>>   Reason: image not found
>> Presumably this is because armadillo is up to version 10 in my system:
>> > ll /usr/local/opt/armadillo/lib/
>> total 576
>> drwxr-xr-x   6 username  staff     192 Oct 28 09:06 .
>> drwxr-xr-x  10 username  staff     320 Oct 28 09:06 ..
>> -r--r--r--   1 username  staff  293580 Oct 28 09:06
>> libarmadillo.10.1.1.dylib
>> lrwxr-xr-x   1 username  staff      25 Oct 28 09:06 libarmadillo.10.dylib
>> -> libarmadillo.10.1.1.dylib
>> lrwxr-xr-x   1 username  staff      21 Oct 28 09:06 libarmadillo.dylib ->
>> drwxr-xr-x   3 username  staff      96 Oct 28 09:06 pkgconfig
>> I've installed goal via homebrew.
>> Thanks for any help.
>> John
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201111/aa44a1fc/attachment.html>
