[gdal-dev] Oracle Spatial Driver: Is it possible to append features to a table?
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Wed Nov 11 07:19:29 PST 2020
It should work. Write your two first ogr2ogr commands (the initial one and
first to append) as a whole but without OCI connection details. The -nln
parameter must appear in the append command if I remember right.
-Jukka Rahkonen-
KreÃ, Marius wrote
> Dear GDAL developers and users,
> I want to write contour polygons into an Oracle Spatial database. Because
> the area is quite large, I would like to calculate them in smaller boxes
> and write them into the table one after the other. But as far as I can
> see, it is not possible to append features to a table. You can only create
> a new one, overwrite or truncate it. Even if I first write it into a
> shapefile and then try to write it in the database with ogr2ogr, it
> ignores the -append and -update options.
> Is it correct that it doesn't work or did I miss anything? Do you know a
> better solution?
> Thanks for your help,
> Marius Kress
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
