[gdal-dev] gdal-dev Digest, Vol 198, Issue 14
Ari Jolma
ari.jolma at gmail.com
Wed Nov 11 21:51:37 PST 2020
It's already some time I worked with the WCS driver and then most of the
time went into wondering the small differences between servers.
With https://demo.geo-solutions.it/geoserver/wcs I can do this workflow:
1) gdalinfo "WCS:https://demo.geo-solutions.it/geoserver/wcs"
..takes some time as it makes calls and then it stores into
$HOME/.gdal/wcs_cache/
(note the version added to the URL)
- an entry into db:
KfSWH=https://demo.geo-solutions.it/geoserver/wcs?version=2.0.1
- two files: KfSWH.xml and KfSWH.aux.xml, the first is the capabilities
XML, the 2nd is GDAL aux XML
and prints gdalinfo output, which contains for example the subdatasets.
You'll get the same output, but faster, if you issue the above command again
From the subdataset list I can now pick one coverage.
2) gdalinfo
"WCS:https://demo.geo-solutions.it/geoserver/wcs?version=2.0.1&coverage=nurc__Img_Sample"
.. takes again some time as it makes calls and then it stores new data
into the cache
cJLrY=https://demo.geo-solutions.it/geoserver/wcs?version=2.0.1&coverage=nurc__Img_Sample
- three files: cJLrY.xml, cJLrY.xml.aux.xml, cJLrY.DC.xml, the first is
the WCS_GDAL XML
and prints
ERROR 1: HTTP error code : 404
ERROR 1: InvalidSubsetting: Empty intersection after subsetting
so it probably needs some special switches, which are described in the
documentation.
Best,
Ari
Rahkonen Jukka (MML) kirjoitti 11.11.2020 klo 23.55:
> Hi,
> Sorry, this is something that I am not familiar with. The developer of
> the WCS plugin probably could tell if it is at all supported to use
> the XML file as input like you tried. I wonder if Ari Jolma happens to
> follow the list. And what QGIS does is all mystery for me.
> -Jukka Rahkonen-
> *Lähettäjä:* 1520 gis <juliermeopensourcedeveloper at gmail.com>
> *Lähetetty:* keskiviikko 11. marraskuuta 2020 16.55
> *Vastaanottaja:* Rahkonen Jukka (MML)
> <jukka.rahkonen at maanmittauslaitos.fi>
> *Aihe:* Re: gdal-dev Digest, Vol 198, Issue 14
> Dear Jukka Rahkonen,
> Thank you very much for your patience, time, and detailed information
> given to my questions. I appreciated it all.
> In your discussion in [1], I could get the a xml sample [2].
> In [3], you will get the whole image available in geoserver. And in
> [4], You will get the Image [3] subset.
> My goal is to load [3] e [4], mainly [4] subset in QGIS, by adding a
> XML raster. It is important to mention that I am not interested in
> accessing the raster data through a WCS connection, I am
> actually adding a xml as a raster (Ctrl + Shift + R).
> If you save the xml file in [2] or [5] and add to QGIS as raster data
> (Ctrl + Shift + R), you will get the image.
> Now, the xml you find in [5] was created by just changing the tag
> values according to your discussion in [1]. I could not find through
> gdal documentation how to generate this xml using gdal_translate.
> GDAL_WMTS driver stunningly does the job. See
> //gdal_translate"WMTS:http://maps.wien.gv.at/wmts/1.0.0/WMTSCapabilities.xml,layer=lb"wmts*.*xml*-*ofWMTS.
> My need is to create a xml for [4] just like the one available in [5].
> I need to access the image in [4] subset using GDAL_WCS.
> The command line in [6] creates a tiff image, but I am looking for the
> xml that when loaded to QGIS ingest the WCS service and loads the image.
> I wonder If there is a xml tag to the subset available in [4]. Or if
> there is a command line for gdal_translate that can generate XML in 3,
> and most importantly, generate a xml for the subset in [4], similar to
> gda GDAL_WMTS driver shown above.
> Sorry for the long e-mail. I have no words to thank you for your help
> and consideration of my messages.
> Kinds Regards
> Julierme
> [1]
> https://geoserver-users.narkive.com/2FVEaNlm/define-geoserver-bounding-box-using-gdal-s-wcs-driver
> [2] XML Sample
> <WCS_GDAL>
> <ServiceURL>https://demo.geo-solutions.it/geoserver/wcs?version=2.0.1&</ServiceURL>
> <CoverageName>nurc:mosaic</CoverageName>
> <GetCoverageExtra>&BoundingBox=6.346,36.492,20.83,46.591</GetCoverageExtra>
> </WCS_GDAL>
> [3]https://demo.geo-solutions.it/geoserver/wcs?Service=WCS
> &version=2.0.1
> &bbox=-130.85168,20.7052,-62.0054,54.1141
> &request=GetCoverage
> &coverageId=nurc:Img_Sample
> &format=image/png
> [4] https://demo.geo-solutions.it/geoserver/wcs?service=WCS
> <https://demo.geo-solutions.it/geoserver/wcs?service=WCS>
> &version=2.0.1
> &SubsettingCRS=EPSG:4326
> &SUBSET=Long(-100,-80)&SUBSET=Lat(30,40)
> &format=image/png
> [5] <WCS_GDAL>
> <CoverageName>nurc:Img_Sample</CoverageName>
> <GetCoverageExtra>&BoundingBox=-130.85168,20.7052,-62.0054,54.1141</GetCoverageExtra>
> </WCS_GDAL>
> [6] gdal_translate -oo CACHE=wcs_cache -oo CLEAR_CACHE -oo
> INTERLEAVE=PIXEL -projwin 377418 6683393.87938218 377717.879386966
> 6683094 -oo Subset="time(1985-01-01T00:00:00.000Z)" -outsize 60 0
> "WCS:https://beta-karttakuva.maanmittauslaitos.fi/wcs/service/ows?version=2.0.1&coverage=ortokuva__ortokuva"
> scaled.tiff
> On Tue, Nov 10, 2020 at 1:23 PM Rahkonen Jukka (MML)
> <mailto:jukka.rahkonen at maanmittauslaitos.fi>> wrote:
> Hi,
> Sending mail just to you because this is not a proper answer but
> rather some first-aid. Normally we keep the discussion on the list
> to other users can help, and get help by the same.
> Sorry, -spat is for ogr2ogr, in gdal_translate it is -projwin.
> Give the bbox coordinates as in the help:
> [-projwin ulx uly lrx lry]
> upper left x upper left y lower right x lower right y
> Hope that you get it to work but I may look at this deeper when I
> have better time for that.
> First step is to create the XML file. Then test is with gdalinfo,
> when it reports something that makes sense you can continue with
> gdal_translate and all the standard options that it has.
> WCS 2.0 is pretty easy to use also with plain hand written http
> requests, read the standard for learning. I would forget older
> versions.
> Test URL for you
> https://demo.geo-solutions.it/geoserver/wcs?SERVICE=WCS&REQUEST=GetCoverage&VERSION=2.0.1&CoverageId=nurc__mosaic&subset=Long(8.0,8.1)&subset=Lat(38,38.1)&format=tiff
> Unfortunately the server was down earlier today, I hope it works now.
> -Jukka-
> <mailto:juliermeopensourcedeveloper at gmail.com>>
> *Lähetetty:* tiistai 10. marraskuuta 2020 18.10
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> <mailto:gdal-dev at lists.osgeo.org>; Rahkonen Jukka (MML)
> Thank you very much for your reply.
> First of all, my apologies for my lack of knowledge about using
> GDAL_WCS driver. Let me give more details about the issues I am
> facing.
> Extract of
> http://172.21.14.45:8181/geoserver/ows/wcs?request=GetCapabilities
> is shown in [1].
> Regarding gdal_translate GDAL_WCS driver Image subset extract,
> looking at https://gdal.org/drivers/raster/wcs.html#examples, I
> tried the following:
> Similar to GDAL_WMTS
> <gdal_translate"WMTS:http://maps.wien.gv.at/wmts/1.0.0/WMTSCapabilities.xml,layer=lb"wmts*.*xml*-*ofWMTS>,
> I tried running:
> (1)
> gdal_translate
> "WCS:http://172.21.14.45:8181/geoserver/wcs?version=2.0.1&coverage=deter-amazonia__CBERS-4_AWFI_170_111_21052020"
> CBERS-4_AWFI_170_111_21052020.xml
> *The response:* I did not get the xml as wmts.xml showed above
> Note: Including the -of option (WCS), the outcome fails
> (2)
> gdal_translate
> "WCS:http://172.21.14.45:8181/geoserver/ows/wcs?request=GetCapabilities&coverage=deter-amazonia__CBERS-4_AWFI_170_111_21052020"
> -spat -58 -11 -57.75 -10.7 \
> *The response:* There is no -spat option for gdal_translate
> *gdal_translate --help*
> Usage: gdal_translate [--help-general] [--long-usage]
> [-ot {Byte/Int16/UInt16/UInt32/Int32/Float32/Float64/
> CInt16/CInt32/CFloat32/CFloat64}] [-strict]
> [-of format] [-b band] [-mask band] [-expand {gray|rgb|rgba}]
> [-outsize xsize[%]|0 ysize[%]|0] [-tr xres yres]
> [-r {nearest,bilinear,cubic,cubicspline,lanczos,average,mode}]
> [-unscale] [-scale[_bn] [src_min src_max [dst_min
> dst_max]]]* [-exponent[_bn] exp_val]*
> [-srcwin xoff yoff xsize ysize] [-epo] [-eco]
> [-projwin ulx uly lrx lry] [-projwin_srs srs_def]
> [-a_srs srs_def] [-a_ullr ulx uly lrx lry] [-a_nodata value]
> [-a_scale value] [-a_offset value]
> [-nogcp] [-gcp pixel line easting northing [elevation]]*
> |-colorinterp{_bn} {red|green|blue|alpha|gray|undefined}]
> |-colorinterp {red|green|blue|alpha|gray|undefined},...]
> [-mo "META-TAG=VALUE"]* [-q] [-sds]
> [-co "NAME=VALUE"]* [-stats] [-norat]
> [-oo NAME=VALUE]*
> src_dataset dst_dataset
> [1] WCS GetCapabilities request
> <wcs:CoverageSummary>
> <ows:Title>CBERS-4_AWFI_170_111_21052020</ows:Title>
> <ows:Abstract>Generated from GeoTIFF</ows:Abstract>
> <ows:Keywords>
> <ows:Keyword>deter-amazonia-CBERS-4_AWFI_170_111_21052020</ows:Keyword>
> <ows:Keyword>WCS</ows:Keyword>
> <ows:Keyword>GeoTIFF</ows:Keyword>
> </ows:Keywords>
> <wcs:CoverageId>deter-amazonia__CBERS-4_AWFI_170_111_21052020</wcs:CoverageId>
> <wcs:CoverageSubtype>RectifiedGridCoverage</wcs:CoverageSubtype>
> <ows:WGS84BoundingBox>
> <ows:LowerCorner>-63.280290728152664
> -13.794296142085976</ows:LowerCorner>
> <ows:UpperCorner>-53.624004749255874
> -5.636644661059637</ows:UpperCorner>
> </ows:WGS84BoundingBox>
> <ows:BoundingBox crs="http://www.opengis.net/def/crs/EPSG/0/EPSG:4326">
> </ows:BoundingBox>
> </wcs:CoverageSummary>
> Any comment will be very appreciated.
> GDAL website <https://gdal.org/drivers/raster/wmts.html> provides
> examples on how to run GDAL_WMTS driver in order to get a wmts xml
> file. I have looked in https://gdal.org/drivers/raster/wcs.html
> and could not find an example pointing to -spat option. I got an
> -spat option
> togdal_grid
> <https://gdal.org/programs/gdal_grid.html?highlight=spat#cmdoption-gdal_grid-spat>
> though.
> gdal_translate
> *-*of WMTS
> gdal_translate
> "WCS:http://www.dpi.inpe.br/fipcerrado-geoserver/ows/wcs?request=GetCapabilities"
> -oo CoverageName=deter-cerrado:CBERS-4_AWFI_161_099_13072018
> CBERS-4_AWFI_161_099_13072018.xml -of WCS
> On Mon, Nov 9, 2020 at 5:00 PM <gdal-dev-request at lists.osgeo.org
> <mailto:gdal-dev-request at lists.osgeo.org>> wrote:
> Send gdal-dev mailing list submissions to
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> To subscribe or unsubscribe via the World Wide Web, visit
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> gdal-dev-owner at lists.osgeo.org
> <mailto:gdal-dev-owner at lists.osgeo.org>
> When replying, please edit your Subject line so it is more
> specific
> than "Re: Contents of gdal-dev digest..."
> Today's Topics:
> 1. Re: Selecting just the geometry column with OGR SQL
> (Even Rouault)
> 2. Re: Selecting just the geometry column with OGR SQL
> (Rahkonen Jukka (MML))
> 3. Re: WCS_GDAL Driver Image SubSet Request (jratike80)
> Message: 1
> Date: Mon, 09 Nov 2020 16:09:45 +0100
> From: Even Rouault <even.rouault at spatialys.com
> <mailto:even.rouault at spatialys.com>>
> To: gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> Cc: "Rahkonen Jukka (MML)"
> Subject: Re: [gdal-dev] Selecting just the geometry column
> with OGR
> SQL
> Message-ID: <1659214.2tRo4lr4Oo at even-i700
> <mailto:1659214.2tRo4lr4Oo at even-i700>>
> Content-Type: text/plain; charset="us-ascii"
> Jukka,
> > I believe that OGR SQL dialect adds the geometry column into
> SQL selection
> > by default. Am I right with this? I volunteer to edit the
> documentation
> > https://gdal.org/user/ogr_sql_dialect.html if this is the
> case. But what I
> > can't understand is another side of the story, how to select
> just the
> > geometry field with OGR SQL dialect from some data sources.
> > This command returns both time column and geometry from GML
> > ogrinfo -sql "select time from timetest" timetest.gml
> > I can select just the geometry from geometry column named as
> > "geometryProperty" by ogrinfo -sql "select geometryProperty
> from timetest"
> > timetest.gml
> > The behavior is the same with SpatiaLite when I use
> "-dialect OGRSQL".
> > Geometry is selected automatically but it can be selected
> also by name. But
> > I cannot discover any way to select just the geometry field
> from shapefile.
> > Is it because geometry column in shapefile does not have any
> name as this
> > Python test seems to prove?
> > >>> from osgeo import ogr
> > >>> shp_ds = ogr.Open('timetest.shp')
> > >>> shp_lyr = shp_ds.GetLayer(0)
> > >>> shp_lyr.GetGeometryColumn()
> > OpenJUMP JML driver does not report a name for geometry
> column either. Is it
> > rather an exception that drivers give names for the geometry
> columns? I
> > know I can select only the geometry column with the SQLite
> dialect, but I
> > am curious.
> Indeed, in OGR SQL, if the geometry column has a non-empty
> name (typically for
> database drivers), you can use it to select it. When the
> is empty, such as in the shapefile or OpenJUMP driver, you can
> use
> _ogr_geometry_ (with leading and trainling underscore) to
> select it. This is
> likely undocumented.
> As far as I can see, this was introduced per
> https://github.com/OSGeo/gdal/commit/1519dcb00bd7802d2f701114f0e1cb9b524a547f
> to fix an issue with comparison with empty string literals
> (this was before
> OGR enforced the difference between single-quoted string
> literals and double-
> quoted identifiers)
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> Message: 2
> Date: Mon, 9 Nov 2020 15:35:11 +0000
> From: "Rahkonen Jukka (MML)"
> To: Even Rouault <even.rouault at spatialys.com
> <mailto:even.rouault at spatialys.com>>,
> "gdal-dev at lists.osgeo.org
> <mailto:gdal-dev at lists.osgeo.org>" <gdal-dev at lists.osgeo.org
> <mailto:gdal-dev at lists.osgeo.org>>
> with OGR
> SQL
> Message-ID:
> <d59795ddfd994dee9f5eca836361324a at maanmittauslaitos.fi
> <mailto:d59795ddfd994dee9f5eca836361324a at maanmittauslaitos.fi>>
> Even Rouault wrote:
> maanantai 9. marraskuuta 2020 17.10
> > Jukka,
> into SQL
> >> selection by default. Am I right with this? I volunteer to
> edit the
> >> documentation https://gdal.org/user/ogr_sql_dialect.html
> <https://gdal.org/user/ogr_sql_dialect.html> if this is
> >> the case. But what I can't understand is another side of
> the story,
> >> how to select just the geometry field with OGR SQL dialect
> ogrinfo
> >> -sql "select time from timetest" timetest.gml I can select
> just the
> >> geometry from geometry column named as "geometryProperty"
> by ogrinfo
> >> -sql "select geometryProperty from timetest"
> >> timetest.gml
> "-dialect OGRSQL".
> also by
> >> name. But I cannot discover any way to select just the
> geometry field from shapefile.
> any name as
> >> this Python test seems to prove?
> column either.
> >> Is it rather an exception that drivers give names for the
> geometry
> >> columns? I know I can select only the geometry column with
> the SQLite
> >> dialect, but I am curious.
> > Indeed, in OGR SQL, if the geometry column has a nonempty
> name (typically for
> can use
> select it. This is likely undocumented.
> (this was before OGR enforced the
> > difference between single-quoted string literals and
> double- quoted identifiers)
> I could not manage to guess the right syntax for Windows right
> ahead but solved the quiz easily
> with your double-quote hint
> First trial:
> ogrinfo -sql "select _ogr_geometry_ from timetest" timetest.shp
> INFO: Open of `timetest.shp'
> using driver `ESRI Shapefile' successful.
> ERROR 1: SQL Expression Parsing Error: syntax error,
> unexpected $undefined. Occurred around :
> Second trial:
> ogrinfo -sql "select \"_ogr_geometry_\" from timetest"
> timetest.shp
> -Jukka-
> > Even
> http://www.spatialys.com <http://www.spatialys.com>
> Message: 3
> Date: Mon, 9 Nov 2020 08:47:05 -0700 (MST)
> From: jratike80 <jukka.rahkonen at maanmittauslaitos.fi
> Subject: Re: [gdal-dev] WCS_GDAL Driver Image SubSet Request
> Message-ID: <1604936825138-0.post at n6.nabble.com
> <mailto:1604936825138-0.post at n6.nabble.com>>
> Content-Type: text/plain; charset=us-ascii
> Hi,
> Do you want to make is somehow impossible to request data
> beyound the
> BoundingBox that you defined in the XML file? If you just want
> to get data
> from the rectangle that you or your users define,
> gdal_translate with the
> regular -spat option should work out-of-the-box.
> -Jukka Rahkonen-
> juliermeopensourcedeveloper wrote
> > Hi all,
> > Is it possible to define a bounding box in order to request
> a coverage
> > subset using the GDAL WCS Driver?
> > I have tried the code in [1]. I am trying to get
> information only for the
> > bbox_interest=( -58,-11,-57.75,-10.75) as shown below,
> however the subset
> > image or bbox_interest request has not been delivered. The
> West Longitude
> > reaches -50.17 and The Lower Latitude reaches -18.92 which
> are limits out
> > of the bbox_interest.
> > The image extent is:
> > <GetCoverageExtra>
> &BoundingBox=-63.280290728152664,-13.794296142085976,-53.624004749255874,-5.636644661059637
> > </GetCoverageExtra>
> > Any comment on this issue will be greatly appreciated.
> > Thank you very much for your time in advance.
> > *CODE [1]:*
> > <WCS_GDAL>
> > <ServiceURL>
> > http://172.21.14.45:6060/geoserver/wcs?version=1.0.0&
> > ServiceURL>
> > <CoverageName>
> > cbers_deter_amazonia:CBERS-4_AWFI_170_111_21052020
> > CoverageName>
> > <GetCoverageExtra>
> > &BoundingBox=-58,-11,-57.75,-10.75
> > </GetCoverageExtra>
> > <CoverageOffering>
> > <description>
> > </description>
> > <name>
> > </name>
> > <label>
> > </label>
> > <lonLatEnvelope srsName="urn:ogc:def:crs:OGC:1.3:CRS84">
> > <pos>
> > -58 -11
> > </pos>
> > <pos>
> > -57.75 -10.75
> > </pos>
> > </lonLatEnvelope>
> > <keywords>
> > <keyword>
> > WCS
> > </keyword>
> > <keyword>
> > GeoTIFF
> > </keyword>
> > </keywords>
> > <domainSet>
> > <spatialDomain>
> > <Envelope srsName="EPSG:4326">
> > <pos>
> > -58 -11
> > </pos>
> > <pos>
> > -57.75 -10.75
> > </pos>
> > </Envelope>
> > <RectifiedGrid dimension="2" srsName="EPSG:4326">
> > <limits>
> > <GridEnvelope>
> > <low>
> > 0 0
> > </low>
> > <high>
> > 0 0
> > </high>
> > </GridEnvelope>
> > </limits>
> > <axisName>
> > x
> > </axisName>
> > <axisName>
> > y
> > </axisName>
> > <origin>
> > <pos>
> > -58 -10.75
> > </pos>
> > </origin>
> > <offsetVector>
> > 0.005364603321609328 0.0
> > </offsetVector>
> > <offsetVector>
> > 0.0 -0.004532028600570188
> > </offsetVector>
> > </RectifiedGrid>
> > </spatialDomain>
> > </domainSet>
> > <rangeSet>
> > <RangeSet>
> > <name>
> > </name>
> > <label>
> > </label>
> > <axisDescription>
> > <AxisDescription>
> > <name>
> > Band
> > </name>
> > <label>
> > Band
> > </label>
> > <values>
> > <interval>
> > <min>
> > 1
> > </min>
> > <max>
> > 4
> > </max>
> > </interval>
> > </values>
> > </AxisDescription>
> > </axisDescription>
> > </RangeSet>
> > </rangeSet>
> > <supportedCRSs>
> > <requestResponseCRSs>
> > EPSG:4326
> > </requestResponseCRSs>
> > </supportedCRSs>
> > <supportedFormats nativeFormat="GeoTIFF">
> > <formats>
> > GeoTIFF
> > </formats>
> > <formats>
> > GIF
> > </formats>
> > <formats>
> > JPEG
> > </formats>
> > <formats>
> > PNG
> > </formats>
> > <formats>
> > TIFF
> > </formats>
> > </supportedFormats>
> > <supportedInterpolations default="nearest neighbor">
> > <interpolationMethod>
> > nearest neighbor
> > </interpolationMethod>
> > bilinear
> > bicubic
> > </supportedInterpolations>
> > </CoverageOffering>
> > <PreferredFormat>
> > GeoTIFF
> > </PreferredFormat>
> > <BandCount>
> > 4
> > </BandCount>
> > <BandType>
> > Byte
> > </BandType>
> > </WCS_GDAL>
> > gdal-dev at .osgeo <mailto:gdal-dev at .osgeo>
> Sent from:
> http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> Subject: Digest Footer
> End of gdal-dev Digest, Vol 198, Issue 14
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201112/efb4eed8/attachment-0001.html>
