[gdal-dev] gdal-dev Digest, Vol 198, Issue 14
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Thu Nov 12 01:16:56 PST 2020
Hi Ari,
I fear that user cannot control this with the switches. This is the reason
for the error:
WCS: Requesting
http://demo.geo-solutions.it/geoserver/wcs?SERVICE=WCS&REQUEST=GetCoverage&VERSION=2.0.1&COVERAGEID=nurc__mosaic&SUBSET=Long(6.3953399152693953,6.3953399152693953)&SUBSET=Lat(46.541601968340089,46.541601968340089)&Format=image/tiff
Thus GDAL creates subsets with lower limit = upper limit which makes the
bbox into a point. That it probably not intentional. I think it is done with
the code that begins from
https://github.com/OSGeo/gdal/blob/master/gdal/frmts/wcs/wcsdataset.cpp#L562
If theory interests, there has been discussions within the OGC WCS group
about the validity of such request. It may be that the server should expand
the bbox and send tiff with one pixel as an output. If the subsets were
written for slicing
SUBSET=Long(6.3953399152693953)
&SUBSET=Lat(46.541601968340089)
then tiff as outputformat is not possible because image has always two
dimensions but here 0 dimensionality (point) is requested. But this is a
sidepath because I believe that the WCS driver wants to read a small area
from WCS as a sample, not just one pixel.
-Jukka-
Ari Jolma-2 wrote
> 2) gdalinfo
> "WCS:https://demo.geo-solutions.it/geoserver/wcs?version=2.0.1&coverage=nurc__Img_Sample"
> .. takes again some time as it makes calls and then it stores new data
> into the cache
> cJLrY=https://demo.geo-solutions.it/geoserver/wcs?version=2.0.1&coverage=nurc__Img_Sample
> - three files: cJLrY.xml, cJLrY.xml.aux.xml, cJLrY.DC.xml, the first is
> the WCS_GDAL XML
> and prints
> ERROR 1: HTTP error code : 404
> ERROR 1: InvalidSubsetting: Empty intersection after subsetting
> so it probably needs some special switches, which are described in the
> documentation.
> Best,
> Ari
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
