[gdal-dev] Encoding when creating pdf
Even Rouault
even.rouault at spatialys.com
Sun Nov 15 14:50:46 PST 2020
Aneta,
https://gdal.org/drivers/vector/pdf.html#vector-pdf mentions that LABEL
strings are limitted to ASCII
Jorge,
the fact that it renders fine with QGIS is that the rendering of labels is
done by QGIS through its own rendering engine with a PDF output. It then uses
the GDAL PDF driver to assemble the rendering of the different layers with a
layer tree, and add the georeferencing. It doesn't use the basic in-built GDAL
PDF vector rendering capabilities.
Even
http://www.spatialys.com
