[gdal-dev] Encoding when creating pdf
Jorge Gustavo Rocha
jgr at osgeopt.pt
Mon Nov 16 16:30:47 PST 2020
Hi Even,
Thank you for the explanation (and for correcting me).
Aneta,
You can try QGIS as a possible workaround. You can use the Atlas feature
(GUI based) or write a small PyQGIS script, if you want to run it on a
headless server, on the command line.
Regards,
Jorge
Às 22:50 de 15/11/20, Even Rouault escreveu:
> Aneta,
> https://gdal.org/drivers/vector/pdf.html#vector-pdf mentions that LABEL
> strings are limitted to ASCII
> Jorge,
> the fact that it renders fine with QGIS is that the rendering of labels is
> done by QGIS through its own rendering engine with a PDF output. It then uses
> the GDAL PDF driver to assemble the rendering of the different layers with a
> layer tree, and add the georeferencing. It doesn't use the basic in-built GDAL
> PDF vector rendering capabilities.
> Even
OSGeo Portugal
NIF: 509588190
email: geral at osgeopt.pt
https://www.osgeopt.pt/
Próximo evento: SASIG 2017, 20 a 22 de novembro, Porto
Mais informações: http://osgeopt.pt/sasig2017/
