[gdal-dev] GDAL conda build
Paul Harwood
runette at gmail.com
Tue Nov 17 03:44:01 PST 2020
Does anyone know the background behind "osgeo-forge"?
On Tue, 17 Nov 2020 at 11:33, Jon Morris <Jon.Morris at jbarisk.com> wrote:
> Hi Jeff,
> I don't feel I know enough about the process to start to update that page,
> as there is quite a lot of work to do!
> In the end the recipe at
> https://github.com/osgeo-forge/libgdal-filegdb-feedstock worked for me,
> with a couple of minor tweaks to remove some warnings from the log.
> Updating it to v3.2.0 was also straightforward, only the version and md5
> need to be updated. Once this is built, the libgdal-filegdb package can be
> installed to an environment containing conda-forge GDAL and you now have
> full FileGDB write support.
> Thanks,
> Jon
> -----Original Message-----
> From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Jeff
> McKenna
> Sent: 16 November 2020 12:54
> To: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] GDAL conda build
> On 2020-11-11 9:00 a.m., Jon Morris wrote:
> > Hi Paul,
> > Thanks for your reply. The only reason we're trying to build locally
> > is to add FileGDB support - if there is a better way to add FileGDB
> > write support to conda-forge GDAL, I'd love to hear it! The GDAL docs
> > are very out of date when it comes to building on Windows - the "GDAL
> > Windows Building example for Plugins" links to
> > https://trac.osgeo.org/gdal/wiki/BuildingOnWindows
> > <https://trac.osgeo.org/gdal/wiki/BuildingOnWindows>.
> Hi Jon,
> For 10+ years we maintained the FileGDB build steps for Windows etc at
> https://trac.osgeo.org/gdal/wiki/FileGDB
> In general, as a person compiling GDAL, you should bookmark the
> priceless "BuildHints" wiki page, see the "External Library" section
> where various driver compile howtos are listed, at
> https://trac.osgeo.org/gdal/wiki/BuildHints
> (you can see how for users compiling drivers that a wiki is a lifeline,
> recording build steps that may be 5 years old and 'stale', yet
> containing valuable information to the user)
> Please consider recording your steps as well, for other users, as you
> travel down this path.
> Thanks!
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> co-founder of FOSS4G
> http://gatewaygeo.com/
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> [JBA COVID-19 statement]<
> https://www.jbagroup.co.uk/sites/www.jbagroup.co.uk/files/documents/15-030%20JBA%20Business%20Continuity%20Briefing%20-%20Latest.pdf
> T +44 (0) 1756 799919
> www.jbarisk.com<http://www.jbarisk.com>
> [Visit our website]<http://www.jbarisk.com> [
> http://www.jbagroup.co.uk/imgstore/JBA-Email-Sig-Icons-LINKEDIN.png] <
> https://www.linkedin.com/in/jon-morris-a2897b4/> [Follow us on Twitter] <
> https://twitter.com/jbarisk>
> Find out more about us here: www.jbarisk.com<http://www.jbarisk.com/> and
> follow us on Twitter @JBARisk<http://twitter.com/JBARisk> and LinkedIn<
> https://www.linkedin.com/company/2370847?trk=tyah&trkInfo=clickedVertical%3Acompany%2CclickedEntityId%3A2370847%2Cidx%3A2-1-2%2CtarId%3A1447414259786%2Ctas%3AJBA%20RISK%20MANAGEMENT
> The JBA Group supports the JBA Trust.
> All JBA Risk Management's email messages contain confidential information
> and are intended only for the individual(s) named. If you are not the named
> addressee you should not disseminate, distribute or copy this e-mail.
> Please notify the sender immediately by email if you have received this
> email by mistake and delete this email from your system.
> JBA Risk Management Limited is registered in England, company number
> 07732946, 1 Broughton Park, Old Lane North, Broughton, Skipton, North
> Yorkshire, BD23 3FD, Telephone: +441756799919
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201117/816b46bb/attachment.html>
