[gdal-dev] GDAL conda build
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Nov 17 05:58:24 PST 2020
Hi Jon,
You can press edit and add a section with all of your own notes
(everything you have written here in your emails to the list) to the
bottom of that page, so that way you avoid the thinking of 'i must
update the entire wiki page'. (no exclamation point needed)
thanks,
-jeff
Jeff McKenna
MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
On 2020-11-17 7:33 a.m., Jon Morris wrote:
> Hi Jeff,
> I don't feel I know enough about the process to start to update that page, as there is quite a lot of work to do!
> In the end the recipe at https://github.com/osgeo-forge/libgdal-filegdb-feedstock worked for me, with a couple of minor tweaks to remove some warnings from the log. Updating it to v3.2.0 was also straightforward, only the version and md5 need to be updated. Once this is built, the libgdal-filegdb package can be installed to an environment containing conda-forge GDAL and you now have full FileGDB write support.
> Thanks,
> Jon
> -----Original Message-----
> From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Jeff McKenna
> Sent: 16 November 2020 12:54
> To: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] GDAL conda build
> On 2020-11-11 9:00 a.m., Jon Morris wrote:
>> Hi Paul,
>> Thanks for your reply. The only reason we're trying to build locally
>> is to add FileGDB support - if there is a better way to add FileGDB
>> write support to conda-forge GDAL, I'd love to hear it! The GDAL docs
>> are very out of date when it comes to building on Windows - the "GDAL
>> Windows Building example for Plugins" links to
>> https://trac.osgeo.org/gdal/wiki/BuildingOnWindows
>> <https://trac.osgeo.org/gdal/wiki/BuildingOnWindows>.
> Hi Jon,
> For 10+ years we maintained the FileGDB build steps for Windows etc at
> https://trac.osgeo.org/gdal/wiki/FileGDB
> In general, as a person compiling GDAL, you should bookmark the
> priceless "BuildHints" wiki page, see the "External Library" section
> where various driver compile howtos are listed, at
> https://trac.osgeo.org/gdal/wiki/BuildHints
> (you can see how for users compiling drivers that a wiki is a lifeline,
> recording build steps that may be 5 years old and 'stale', yet
> containing valuable information to the user)
> Please consider recording your steps as well, for other users, as you
> travel down this path.
> Thanks!
> -jeff
> Jeff McKenna
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> [JBA COVID-19 statement]<https://www.jbagroup.co.uk/sites/www.jbagroup.co.uk/files/documents/15-030%20JBA%20Business%20Continuity%20Briefing%20-%20Latest.pdf>
> T +44 (0) 1756 799919
> www.jbarisk.com<http://www.jbarisk.com>
> [Visit our website]<http://www.jbarisk.com> [http://www.jbagroup.co.uk/imgstore/JBA-Email-Sig-Icons-LINKEDIN.png] <https://www.linkedin.com/in/jon-morris-a2897b4/> [Follow us on Twitter] <https://twitter.com/jbarisk>
> Find out more about us here: www.jbarisk.com<http://www.jbarisk.com/> and follow us on Twitter @JBARisk<http://twitter.com/JBARisk> and LinkedIn<https://www.linkedin.com/company/2370847?trk=tyah&trkInfo=clickedVertical%3Acompany%2CclickedEntityId%3A2370847%2Cidx%3A2-1-2%2CtarId%3A1447414259786%2Ctas%3AJBA%20RISK%20MANAGEMENT>
> The JBA Group supports the JBA Trust.
> All JBA Risk Management's email messages contain confidential information and are intended only for the individual(s) named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
> Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system.
> JBA Risk Management Limited is registered in England, company number 07732946, 1 Broughton Park, Old Lane North, Broughton, Skipton, North Yorkshire, BD23 3FD, Telephone: +441756799919
