[gdal-dev] GDAL 3.1.2: PROJ_DEBUG
    Even Rouault
    even.rouault at spatialys.com
    Tue Nov 17 10:40:19 PST 2020
On mardi 17 novembre 2020 14:01:07 CET Daniel Mellergård wrote:
> Hi,
> Is setting the environment variable PROJ_DEBUG=3 supposed to work when
> using GDAL3.1.2? Running for example gdalsrsinfo with that environment
> variable set has no effect, but running projinfo (from proj 6.3.2) does.
As PROJ logging goes through GDAL one, you also need to enable CPL_DEBUG=ON
(or CPL_DEBUG=PROJ to restrict to PROJ traces)
Even
http://www.spatialys.com
