[gdal-dev] GDAL 3.1.2: PROJ_DEBUG
Daniel Mellergård
daniel.mellergardh at gmail.com
Wed Nov 18 04:18:17 PST 2020
Thanks!
Den tis 17 nov. 2020 kl 18:40 skrev Even Rouault <even.rouault at spatialys.com
> On mardi 17 novembre 2020 14:01:07 CET Daniel Mellergård wrote:
> > Hi,
> > Is setting the environment variable PROJ_DEBUG=3 supposed to work when
> > using GDAL3.1.2? Running for example gdalsrsinfo with that environment
> > variable set has no effect, but running projinfo (from proj 6.3.2) does.
> As PROJ logging goes through GDAL one, you also need to enable
> CPL_DEBUG=ON
> (or CPL_DEBUG=PROJ to restrict to PROJ traces)
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201118/e87edc1e/attachment-0001.html>
