[gdal-dev] Geometry column name: Field 'OGR_GEOMETRY' not found in source layer
Jorge Gustavo Rocha
jgr at osgeopt.pt
Thu Nov 19 08:11:37 PST 2020
Hi devs,
To get only the geometry column from a shapefile, I can do:
ogrinfo cidade.shp -sql "select OGR_GEOMETRY from cidade"
But this column name is not allowed in the -select option on ogr2ogr:
ogr2ogr -overwrite -skipfailures -update PG:service=estarreja cidade.shp
-select OGR_GEOMETRY
ERROR 1: Field 'OGR_GEOMETRY' not found in source layer.
Shouldn't OGR_GEOMETRY be allowed in -select?
Regards,
Jorge
OSGeo Portugal
NIF: 509588190
email: geral at osgeopt.pt
https://www.osgeopt.pt/
Próximo evento: SASIG 2017, 20 a 22 de novembro, Porto
Mais informações: http://osgeopt.pt/sasig2017/
