[gdal-dev] Geometry column name: Field 'OGR_GEOMETRY' not found in source layer
Even Rouault
even.rouault at spatialys.com
Thu Nov 19 10:27:49 PST 2020
Jorge,
> To get only the geometry column from a shapefile, I can do:
> ogrinfo cidade.shp -sql "select OGR_GEOMETRY from cidade"
This is a bit a misnomer: OGR_GEOMETRY is a special keyword to get the
geometry *type* of a geometry ("POLYGON", "POINT", "LINESTRING"), not the
geometry itself. For that, for format such as shapefile which don't have a
named geometry column, you must use the "_OGR_GEOMETRY_" (quoted with double
quotes as starting with underscore)
> But this column name is not allowed in the -select option on ogr2ogr:
> ogr2ogr -overwrite -skipfailures -update PG:service=estarreja cidade.shp
> -select OGR_GEOMETRY
you can use -sql here as well
Could perhaps make sense to support the special "_ogr_geometry_" field here
too
Even
http://www.spatialys.com
