[gdal-dev] GDAL conda build
Jon Morris Jon.Morris at jbarisk.com
Thu Nov 19 09:06:37 PST 2020
Hi Jeff,
I've updated the wiki, adding a couple of sections about compiling GDAL 2.3+ (requires VC14+) and providing links to the conda recipes that I used. I hope they are useful to anyone else that needs FileGDB write support on Windows.
https://trac.osgeo.org/gdal/wiki/FileGDB
Thanks,
Jon
-----Original Message-----
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Jeff McKenna
Sent: 17 November 2020 14:11
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] GDAL conda build
Hi Jon,
No approval/funnel through one person for edits, you can just add your notes there, so others can follow them someday (and avoid list archive searching).  Over time maybe someone updates or enhances your notes, or not, that's how the wiki thrives.
Thanks for taking the time to do this, most do not (now I could use the exclamation mark here, ha)  :)
-jeff
Jeff McKenna
MapServer Consulting and Training Services co-founder of FOSS4G http://gatewaygeo.com/
On 2020-11-17 10:06 a.m., Jon Morris wrote:
> Hi Jeff,
> No problem, I can do that. Does it need to be approved, or do people just keep editing until we're all happy with it?
> Thanks,
> Jon
> Sent: 17 November 2020 13:58
> Hi Jon,
> You can press edit and add a section with all of your own notes (everything you have written here in your emails to the list) to the bottom of that page, so that way you avoid the thinking of 'i must update the entire wiki page'.  (no exclamation point needed)
> thanks,
> -jeff
> Jeff McKenna
> On 2020-11-17 7:33 a.m., Jon Morris wrote:
>> Hi Jeff,
>> I don't feel I know enough about the process to start to update that page, as there is quite a lot of work to do!
>> In the end the recipe at https://github.com/osgeo-forge/libgdal-filegdb-feedstock worked for me, with a couple of minor tweaks to remove some warnings from the log. Updating it to v3.2.0 was also straightforward, only the version and md5 need to be updated. Once this is built, the libgdal-filegdb package can be installed to an environment containing conda-forge GDAL and you now have full FileGDB write support.
>> Thanks,
>> Jon
>> Sent: 16 November 2020 12:54
>> On 2020-11-11 9:00 a.m., Jon Morris wrote:
>>> Hi Paul,
>>> Thanks for your reply. The only reason we're trying to build locally
>>> is to add FileGDB support - if there is a better way to add FileGDB
>>> write support to conda-forge GDAL, I'd love to hear it! The GDAL docs
>>> are very out of date when it comes to building on Windows - the "GDAL
>>> Windows Building example for Plugins" links to
>>> https://trac.osgeo.org/gdal/wiki/BuildingOnWindows
>>> <https://trac.osgeo.org/gdal/wiki/BuildingOnWindows>.
>> Hi Jon,
>> For 10+ years we maintained the FileGDB build steps for Windows etc at
>> In general, as a person compiling GDAL, you should bookmark the
>> priceless "BuildHints" wiki page, see the "External Library" section
>> where various driver compile howtos are listed, at
>> https://trac.osgeo.org/gdal/wiki/BuildHints
>> (you can see how for users compiling drivers that a wiki is a lifeline,
>> recording build steps that may be 5 years old and 'stale', yet
>> containing valuable information to the user)
>> Please consider recording your steps as well, for other users, as you
>> travel down this path.
>> Thanks!
>> -jeff
>> Jeff McKenna
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>> [JBA COVID-19 statement]<https://www.jbagroup.co.uk/sites/www.jbagroup.co.uk/files/documents/15-030%20JBA%20Business%20Continuity%20Briefing%20-%20Latest.pdf>
>> T +44 (0) 1756 799919
>> www.jbarisk.com<http://www.jbarisk.com>
>> [Visit our website]<http://www.jbarisk.com> [http://www.jbagroup.co.uk/imgstore/JBA-Email-Sig-Icons-LINKEDIN.png] <https://www.linkedin.com/in/jon-morris-a2897b4/>  [Follow us on Twitter] <https://twitter.com/jbarisk>
>> Find out more about us here: www.jbarisk.com<http://www.jbarisk.com/> and follow us on Twitter @JBARisk<http://twitter.com/JBARisk> and LinkedIn<https://www.linkedin.com/company/2370847?trk=tyah&trkInfo=clickedVertical%3Acompany%2CclickedEntityId%3A2370847%2Cidx%3A2-1-2%2CtarId%3A1447414259786%2Ctas%3AJBA%20RISK%20MANAGEMENT>
>> The JBA Group supports the JBA Trust.
>> All JBA Risk Management's email messages contain confidential information and are intended only for the individual(s) named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
>> Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system.
>> JBA Risk Management Limited is registered in England, company number 07732946, 1 Broughton Park, Old Lane North, Broughton, Skipton, North Yorkshire, BD23 3FD, Telephone: +441756799919
