[gdal-dev] ogr2ogr is not working for a geojson file
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Tue Nov 24 07:07:20 PST 2020
What is your GDAL version (current is 3.2)? Do you get the same error with
ogr2ogr command line without launching it from Java?
-Jukka Rahkonen-
Ravi Teja Krishna Wuyyuru wrote
> Hi,
>       I have tried converting the file in Centos and Macos but I am facing
> an error as said below. I have analyzed and found that the issue occurs
> only when there is no properties data in geojson file. I have generated
> jars and library files using the java bindings of gdal. Is there any
> dependency that i might have missed cause this issue occurs only for these
> type of files (i.e with no properties data). Can someone help me in
> solving this error.
> Thanks & Regards,
> Ravi Teja
> ---- On Mon, 23 Nov 2020 14:02:24 +0530 Wuyyuru Ravi Teja Krishna <
> ravitejakrishna.w@
> > wrote ----
> Hi team,
>       I am using ogr2ogr with java bindings for conversion of a geojson
> file to a csv file, But I am getting an error as specified below.
> ERROR 10: Pointer 'panMap' is NULL in 'OGR_F_SetFrom'.
> Unable to translate feature 0 from layer map_sample
> Terminating translation prematurely after failed
> translation of layer map_sample (use -skipfailures to skip errors)
> ogr2ogr is invoked as below
> java -cp :gdal.jar -Djava.library.path=libs/ ogr2ogr "-s_srs" "CRS:84"
> "-t_srs" "CRS:84" "-f" "CSV" proplesscsv.csv map_sample.geojson  "-lco"
> "GEOMETRY=AS_WKT"
> I have also attached the sample file I was working with this mail. Kindly
> help me in this conversion failure.
> Thanks & Regards,
> Ravi Teja
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
