[gdal-dev] Adopting Contributor Covenant v2.0 as code of conduct
Even Rouault
even.rouault at spatialys.com
Wed Nov 25 00:40:59 PST 2020
As required by OSGeo for its projects [1] and some institutions that want to
interact with us, I've prepared in https://github.com/OSGeo/gdal/pull/3219 a
pull request adding the Contributor Covenant v2.0 [2] as the code of conduct
for the project.
The only part I modified is the template "be reported to the community leaders
responsible for enforcement at [INSERT CONTACT METHOD]" customized as "be
reported to the community leaders responsible for enforcement at the
OSGeo Code of Conduct reporting private email (conduct-report at osgeo.org) and/
or at a member of the GDAL Project Steering Committee
(refer to https://gdal.org/community.html#project-steering-committee)."
Opinions ?
Even
[1] https://www.osgeo.org/resources/osgeo-code-of-conduct/
[2] https://www.contributor-covenant.org/version/2/0/code_of_conduct
http://www.spatialys.com
