[gdal-dev] Hello it is my first mail about gdal and macOS
Chris Marsh
chris.marsh at usask.ca
Wed Nov 25 07:51:26 PST 2020
Hi Mar,
I'm not totally clear what you're trying to do.
It seems that you're trying to use QGis on MacOS and there is some problem
with GDAL?
PyCharm is a Python IDE whereas gdal is a C++ library. PyCharm will not
help you compile gdal
If you are wanting to compile gdal, the linux instructions are generally
pretty close to what you need on MacOS
https://trac.osgeo.org/gdal/wiki/BuildingOnUnix
This list is more centred on the development of gdal, and I do not think
you'll find what you need here. I know the gdal+Qgis on macos can be
fiddly, I have found the QGIS installer from here
https://qgis.org/en/site/forusers/download.html
to work well, but you might also want to check out qgis from homebrew (
https://brew.sh/) which also takes care of the gdal installation for you
https://formulae.brew.sh/cask/qgis
but if that still doesn't work for you I would post to the QGis mailing
list with a more specific problem + question so they can better help you.
https://qgis.org/en/site/forusers/support.html
Cheers
Chris
On Wed, Nov 25, 2020 at 5:54 AM Marcela P <mps2806 at gmail.com> wrote:
> CAUTION: External to USask. Verify sender and use caution with links and
> attachments. Forward suspicious emails to phishing at usask.ca
> Hi, my name is Mar,
> I need help about how to work gdal in macOS.
> I have got several problems with gdal in qgis and I am attempting to set
> it on pycharm. I am a newbie and I don´t know how to look for help on it.
> Could you help me?
> Thanks in advance
> Mar
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201125/2fce2cb6/attachment.html>
