[gdal-dev] Encoding issue in Linux Container for OGR/GDAL
BrianVance
brian.asp.net at gmail.com
Wed Nov 25 13:30:23 PST 2020
I'm using C# to read a .gdb file. We run this code in docker through a
Linux container.
We are having an encoding issue with a function in OGR that read the string
value from a field.
item.*GetFieldAsString*(field_name);
The GetFieldAsString returns the proper string when its run from an Windows
environment but when run from a Linux Docker Container it returns us wrong
characters like M�.
We have a lot of French Characters in our file like Québec which don't
render properly when run on Linux.
Can anyone suggest a way to fix this?
Regards,
Brian
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
