[gdal-dev] warp srs: xyz format point cloud
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Thu Nov 26 09:35:58 PST 2020
Because you are changing from the raster world into vector world I would it
somehow
- convert raster in native CRS into xyz
- write a vector VRT file for converting xyz data into points
- re-project the point dataset with ogr2ogr
Converting data into PostGIS raster could be more elegant and allows to live
between the two worlds in a flexible way.
-Jukka Rahkonen-
Idan Miara wrote
> Hi all,
> I have a UTM raster that I want to warp translate to xyz format and
> transform the coordinates to EPSG:4326, I could use:
> `gdalwarp -of xyz -t_srs EPSG:4326 utm.tif 4326.xyz`
> But surely I get a 4326 grid, so my data points were altered to fit the
> new
> grid.
> I could write a function that iterates over the pixels and translates each
> point, but is there a more elegant way to transform coordinates without
> forcing the target srs grid?
> Kind regards,
> Idan
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
