[gdal-dev] NMEA files
Even Rouault even.rouault at spatialys.com
Sun Nov 29 15:16:20 PST 2020
On dimanche 29 novembre 2020 22:45:59 CET Paul Harwood wrote:
> Hi
> I am asking just in case someone has solved this problem already.
> Does anyone know of a way to load NMEA format GPS data as OGR points in
> GDAL?
Yes, through the GPSBabel driver
( https://gdal.org/drivers/vector/gpsbabel.html ) provided the gpsbabel
executable is accessible through the PATH.
$ echo '$GPGGA,194546.127,5231.525,N,01323.391,E,1,12,1.0,0.0,M,0.0,M,,*6E
$GPGSA,A,3,01,02,03,04,05,06,07,08,09,10,11,12,1.0,1.0,1.0*30
$GPRMC,194546.127,A,5231.525,N,01323.391,E,2372.1,093.7,200220,000.0,W*40
$GPGGA,194547.127,5231.456,N,01324.467,E,1,12,1.0,0.0,M,0.0,M,,*63
$GPRMC,194547.127,A,5231.456,N,01324.467,E,3968.7,122.8,200220,000.0,W*4F
$GPGGA,194548.127,5230.657,N,01325.713,E,1,12,1.0,0.0,M,0.0,M,,*6F
$GPRMC,194548.127,A,5230.657,N,01325.713,E,3968.7,122.8,200220,000.0,W*43' >
test.nmea
$ ogrinfo test.nmea
INFO: Open of `test.nmea'
      using driver `GPSBabel' successful.
1: tracks (Multi Line String)
2: track_points (Point)
Even
http://www.spatialys.com
