[gdal-dev] NMEA files
Paul Harwood runette at gmail.com
Mon Nov 30 01:57:39 PST 2020
cool. Thanks to both of you.
On Sun, 29 Nov 2020 at 23:16, Even Rouault <even.rouault at spatialys.com>
wrote:
> On dimanche 29 novembre 2020 22:45:59 CET Paul Harwood wrote:
> > Hi
> > I am asking just in case someone has solved this problem already.
> > Does anyone know of a way to load NMEA format GPS data as OGR points in
> > GDAL?
> Yes, through the GPSBabel driver
> ( https://gdal.org/drivers/vector/gpsbabel.html ) provided the gpsbabel
> executable is accessible through the PATH.
> $ echo '$GPGGA,194546.127,5231.525,N,01323.391,E,1,12,1.0,0.0,M,0.0,M,,*6E
> $GPGSA,A,3,01,02,03,04,05,06,07,08,09,10,11,12,1.0,1.0,1.0*30
> $GPRMC,194546.127,A,5231.525,N,01323.391,E,2372.1,093.7,200220,000.0,W*40
> $GPGGA,194547.127,5231.456,N,01324.467,E,1,12,1.0,0.0,M,0.0,M,,*63
> $GPRMC,194547.127,A,5231.456,N,01324.467,E,3968.7,122.8,200220,000.0,W*4F
> $GPGGA,194548.127,5230.657,N,01325.713,E,1,12,1.0,0.0,M,0.0,M,,*6F
> $GPRMC,194548.127,A,5230.657,N,01325.713,E,3968.7,122.8,200220,000.0,W*43'
> test.nmea
> $ ogrinfo test.nmea
> INFO: Open of `test.nmea'
>       using driver `GPSBabel' successful.
> 1: tracks (Multi Line String)
> 2: track_points (Point)
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201130/dfbdedf6/attachment.html>
