[gdal-dev] How does it work FEATURE_SERVER_PAGING?
Even Rouault
even.rouault at spatialys.com
Thu Oct 1 08:35:20 PDT 2020
On jeudi 1 octobre 2020 08:17:15 CEST jratike80 wrote:
> Hi,
> Yes, the result with ogrinfo is the same but probably it is not the right
> tool for testing the paging. With paging GDAL is fetching the first page,
> puts it somewhere, asks more pages, and finally builds a combined dataset
as
> a result. If you let GDAL to do its job and check how it went your should
> see bigger feature count.
There was an issue in the GetFeatureCount() implementation. Now fixed
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201001/27e55fa3/attachment.html>
