[gdal-dev] How does it work FEATURE_SERVER_PAGING?
aborruso aborruso at gmail.com
Thu Oct 1 08:55:55 PDT 2020
if I run the command below in my "GDAL 2.4.4, released 2020/01/08"
ogr2ogr aout.geojson -f GEOJson
"http://sifweb.regione.sicilia.it/arcgis/rest/services/SIF_INCENDI_EXTENDED/MapServer/13/query?where=objectid>0&outfields=*&f=geojson"
-oo FEATURE_SERVER_PAGING=YES --debug on
I have 1000 geojson items and the below debug messages.
A stupid question sorry: is it normal using GDAL 2.4.4 or should I have all
the items?
Or do I must recompile GDAL 2.4.4?
Thank you to all
GNM: GNMRegisterAllInternal
GNM: RegisterGNMFile
GNM: RegisterGNMdatabase
HTTP:
Fetch(http://sifweb.regione.sicilia.it/arcgis/rest/services/SIF_INCENDI_EXTENDED/MapServer/13/query?where=objectid>0&outfields=*&f=geojson)
HTTP: libcurl/7.68.0 OpenSSL/1.1.1g zlib/1.2.11 brotli/1.0.7 libidn2/2.3.0
libpsl/0.21.0 (+libidn2/2.3.0) libssh2/1.8.0 nghttp2/1.40.0 librtmp/2.3
Warning 1: GDAL was built against curl 7.70.0, but is running against
7.68.0. Runtime failure is likely !
HTTP: These HTTP headers were set: Accept: text/plain, application/json
HTTP:
HTTP:
CouchDB: GET /_all_dbs
HTTP: Establish persistent session named 'CouchDB:0x565276ca3f40'.
HTTP:
Fetch(http://sifweb.regione.sicilia.it/arcgis/rest/services/SIF_INCENDI_EXTENDED/MapServer/13/query?where=objectid>0&outfields=*&f=geojson/_all_dbs)
HTTP: These POSTFIELDS were sent:
HTTP: These HTTP headers were set: Content-Type: application/json
HTTP: Ended persistent session named 'CouchDB:0x565276ca3f40'.
HTTP:
GeoJSON: First pass: 100.00 %
GDAL: GDALOpen(/vsimem/http_1/file.dat, this=0x565276daa3b0) succeeds as
GeoJSON.
GDAL:
GDALOpen(http://sifweb.regione.sicilia.it/arcgis/rest/services/SIF_INCENDI_EXTENDED/MapServer/13/query?where=objectid>0&outfields=*&f=geojson,
this=0x565276daa3b0) succeeds as HTTP.
GDAL: GDALDriver::Create(GeoJSON,aout.geojson,0,0,0,Unknown,(nil))
GDALVectorTranslate: 1000 features written in layer 'file'
GDAL:
GDALClose(http://sifweb.regione.sicilia.it/arcgis/rest/services/SIF_INCENDI_EXTENDED/MapServer/13/query?where=objectid>0&outfields=*&f=geojson,
GDAL: GDALClose(aout.geojson, this=0x565276c8ae20)
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
