[gdal-dev] How does it work FEATURE_SERVER_PAGING?
Even Rouault
even.rouault at spatialys.com
Thu Oct 1 09:46:15 PDT 2020
> Warning 1: GDAL was built against curl 7.70.0, but is running against
> 7.68.0. Runtime failure is likely !
Warnings are meant to be taken seriously, especially when formulated that
way!
Your above command works for me on 2.4.4 with a proper build.
You could use a Docker build for example:
https://github.com/OSGeo/gdal/tree/master/gdal/docker
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201001/623ca3c1/attachment.html>
