[gdal-dev] How does it work FEATURE_SERVER_PAGING?
aborruso aborruso at gmail.com
Thu Oct 1 11:04:19 PDT 2020
Hi Even,
if you write that it works, it is not necessary for me to verify this using
the gdal docker build.
I'm sure it works.
I have compiled it again using these steps
wget http://download.osgeo.org/gdal/2.4.4/gdal244.zip
unzip gdal244.zip
cd ./gdal-2.4.4
./configure --prefix=/usr/local --with-sqlite3=/usr/local
--with-spatialite=/usr/local --with-static-proj4=/usr/local
--with-geos=/usr/local/bin/geos-config
make
sudo make install
But I have the same curl warning, because I need to correct some curl
problem. But I have no idea on where to start.
Is it useful to uninstall curl and install it again?
I have Debian GNU/Linux bullseye/sid.
Thank you
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
