[gdal-dev] XMP in COG
Javier Jimenez Shaw j1 at jimenezshaw.com
Thu Oct 1 14:19:22 PDT 2020
Hi
I have seen that XMP is not copied into a COG file when CreateCopy is
called. Actually it is also not done in CreateCopy of GTiff.
Does it make sense to include the copy of this metadata automatically? And
what about other metadata?
Thanks.
Regards
Javier.
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201001/2c64ca7f/attachment.html>
