[gdal-dev] Handling non-standard character encoding
Even Rouault
even.rouault at spatialys.com
Tue Oct 6 02:38:14 PDT 2020
On mardi 6 octobre 2020 14:36:44 CEST Brad Hards wrote:
> While looking at some NITF test data, Ive found a problem in how we handle
> ECS-A (and ECS) characters. BCS-A (essentially ASCII) is fine. However
> MIL-STD-2500C CN2 allows some header fields to be ECS-A, and the test data
> does this.
> Ive also hit TREs with µm, where the µ character is encoded as 0xB5 in
> ECS-A (UTF-8 would be 0xCE 0xBC)
> Id appreciate some guidance on how to best address this. I can see two
> options handle it internal to the NITF driver, or (somehow) modify
> CPLRecode or iconv to handle this special case. Im currently planning the
> former.
Brad,
as I'm not sure we'd have other needs for ECS-A support elsewhere in the codebase, handling
that in the NITF driver is probably fine
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201006/112f588f/attachment.html>
