[gdal-dev] ogr2ogr: debugging slow performance when converting .e00 to other formats
Mike Flannigan
mikeflan at att.net
Mon Oct 12 14:48:37 PDT 2020
I would try the "Geo::E00" module for Perl.
If you can get the file to me, I'll try it
for you. Or you can install Perl and try it
yourself.
I just checked my files, and surprisingly I have
no E00 files. I guess I just convert them and throw
them away, because I remember converting quite a few
in the past. I also remember that the module does
not work on every E00 file, or at least does not
produce what I expect to see.
The "Geo::E00" module at Perl just produces a text file,
which is what I normally want.
Another option is to use QGIS to convert it.
That may be the best option for you.
Mike
On 10/12/20 2:00 PM, gdal-dev-request at lists.osgeo.org wrote:
> Hello all,
> I am new to this list, apologies if this type of question has already been asked. I’m using GDAL/OGR version 3.0.4 on a brand new server with 256GB ram.
> I have a moderately sized (~110MB) .e00 file I would like to convert to another format. The original file appears to be clean; ogrinfo gives no problems opening the file.
> I’ve tried converting this .e00 to shapefile, sqlite, and gpkg and in all cases it appears to create a file (or files depending on the output format) at the beginning but then little appears to happen after that. After several hours the conversion operation is still running, but the files only grow very, very slowly.
> Is there any way to monitor the progress of the ogr2ogr operation or debug what is happening? I feel like there is not a lot more I can do except wait, but the time ogr2ogr is taking seems excessive given the input file size and the slow growth of the output file.
> Thanks for your help,
> Jed
