[gdal-dev] Coordinate space to pixel space with image rotation in python
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Fri Oct 16 08:51:17 PDT 2020
On 2020-10-16 11:49 a.m., Nicolas Cadieux wrote:
> Hi again! (a few months later...)
> What is the best practice for reading a single pixel in the raster?
> structval = raster_band.ReadRaster(column, row, 1, 1, 1, 1,
> raster_band.DataType)
> or
> structval = raster_band.ReadRaster(int(column), int(row), 1, 1, 1, 1,
> Nicolas
> On 2020-01-28 12:30 p.m., Even Rouault wrote:
>> Nicolas,
>>> It's easy to go from coordinate space to pixel space in python using
>>> something like.
>>> pixel_x = int(-124114.3 - geo_transform[0])/geo_transform[1])
>>> What is the trick when there is an image rotation?
>> Compute the inverse geotransform with
>> https://gdal.org/api/raster_c_api.html?highlight=invgeotransform#_CPPv419GDALInvGeoTransformPdPd
>> (gdal.InvGeoTransform(gt) in Python )
>> And then use the coordinates in coordinate space as the input for
>> this inverse geotransform
>> column = inv_gt[0] + X * inv_gt[1] + Y * inv_gt[2]
>> row = inv_gt[3] + X * inv_gt[4] + Y * inv_gt[5]
>>> Also, as a second
>>> very beginner question, what is the difference between geo_transform[2]
>>> and geo_transform[4]?
>> There are defined by the relationships at
>> https://gdal.org/user/raster_data_model.html#affine-geotransform
>> Even
