[gdal-dev] [Docs] Propose localization of gdal documentation
Even Rouault
even.rouault at spatialys.com
Mon Oct 19 01:33:03 PDT 2020
Hi Hiroshi,
> I'd like to propose to move gdal doc to be i18n-ed.
> Now documentations are compiled with sphinx, and sphinx has a good i18n/l10n
> facility, and it is very easy.. If you are welcome for the move, I'd like
> to propose some updates for gdal github project.
> * How to i18n-ed sphinx documentation.
> 1. add `locale_dirs = ['locale/']` to `doc/source/conf.py`
> 2. `$ pip install sphinx-intl`
> 3. run `$ make gettext` and `$ sphinx-intl update -l ja -l de`
> 4. Translate generated PO files under
> `doc/source/locale/<lang>/LC_MESSAGES/` 5. `$ make -Dlanguage=ja html`
> When we are ready to provide i18n documentation with translated PO files,
> we can produce localized html using sphinx on azure-pipelines.
> I'd ike to contribute a Japanese translation of documentations.
> So I have a private project to do that using OmegaT CAT tool.
> https://github.com/miurahr/gdal_docs_ja
Sounds interesting. I assume you won't translate the ~ 1000 pages of doc we
have currently, though ?
We'd probably need some instructions somewhere (doc/README.md ?) to explain
the process on how to create & update translations.
Even
http://www.spatialys.com
