[gdal-dev] GDAL 3.1.4 RC1 available
Joaquim Manuel Freire Luís
jluis at ualg.pt
Mon Oct 19 16:17:05 PDT 2020
Reverting PROJ to
d1a0d95da549f7d32bcd8be408afe1fca62a6fb2
(* Database query: add AuthorityFactory::ObjectType::DYNAMIC_GEODETIC_REFERENCE_FRAME and DYNAMIC_VERTICAL_REFERENCE_FRAME, and make corresponding C API work)
Solved the issue.
-----Original Message-----
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Joaquim Manuel Freire Luís
Sent: Monday, October 19, 2020 11:04 PM
To: Even Rouault <even.rouault at spatialys.com>; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] GDAL 3.1.4 RC1 available
Even,
I'm puzzled with this but after updating and building GDAL+PROJ today (master) one of my MEX dlls that depend on GDAL and PROJ started to error with
Invalid MEX-file 'C:\progs_cygw\GMTdev\gmt5\compileds\gmt6\VC14_64\bin\gmtmex.mexw64': The specified procedure could not be found.
I managed to trace it to this likely source provided by DependencyWalker. I don't get it because it seems to indicate that "proj_crs_get_datum_ensemble" is not exported but that is not the case. Any new use of that function?
Joaquim
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Even Rouault
Sent: Monday, October 19, 2020 3:31 PM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] GDAL 3.1.4 RC1 available
So that we can focus on 3.2.0 and onwards, I have prepared a GDAL/OGR 3.1.4 release candidate, which should be the final one in the 3.1 series.
Pick up an archive among the following ones (by ascending size):
https://download.osgeo.org/gdal/3.1.4/gdal-3.1.4rc1.tar.xz
https://download.osgeo.org/gdal/3.1.4/gdal-3.1.4rc1.tar.gz
https://download.osgeo.org/gdal/3.1.4/gdal314rc1.zip
A snapshot of the gdalautotest suite is also available :
https://download.osgeo.org/gdal/3.1.4/gdalautotest-3.1.4rc1.tar.gz
https://download.osgeo.org/gdal/3.1.4/gdalautotest-3.1.4rc1.zip
GDAL-GRASS plugin:
https://download.osgeo.org/gdal/3.1.4/gdal-grass-3.1.4.tar.gz
The NEWS file is here :
https://github.com/OSGeo/gdal/blob/v3.1.4RC1/gdal/NEWS
I'll call for a vote promoting it to final soon if no serious problems are reported before.
Best regards,
Even
Spatialys - Geospatial professional services http://www.spatialys.com _______________________________________________
gdal-dev mailing list
https://lists.osgeo.org/mailman/listinfo/gdal-dev
