[gdal-dev] GDAL 3.1.4 RC1 available
Even Rouault
even.rouault at spatialys.com
Tue Oct 20 02:00:57 PDT 2020
Joaquim,
Yes GDAL 3.1.4 makes use of the new function proj_crs_get_datum_ensemble() of
PROJ master (tested by checking PROJ version number to be >= 7.2 since this is
queued for the PROJ 7.2 release in a few days). So I suspect you might build
GDAL against the header of a recent PROJ master, but at runtime use an older
version of the .dll that has not the symbol
Even
> Reverting PROJ to
> d1a0d95da549f7d32bcd8be408afe1fca62a6fb2
> (* Database query: add
> AuthorityFactory::ObjectType::DYNAMIC_GEODETIC_REFERENCE_FRAME and
> DYNAMIC_VERTICAL_REFERENCE_FRAME, and make corresponding C API work)
> Solved the issue.
> -----Original Message-----
> From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Joaquim
> Manuel Freire Luís
Sent: Monday, October 19, 2020 11:04 PM
> To: Even Rouault <even.rouault at spatialys.com>; gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] GDAL 3.1.4 RC1 available
> Even,
> I'm puzzled with this but after updating and building GDAL+PROJ today
> (master) one of my MEX dlls that depend on GDAL and PROJ started to error
> with
> Invalid MEX-file
> 'C:\progs_cygw\GMTdev\gmt5\compileds\gmt6\VC14_64\bin\gmtmex.mexw64': The
> specified procedure could not be found.
> I managed to trace it to this likely source provided by DependencyWalker. I
> don't get it because it seems to indicate that
> "proj_crs_get_datum_ensemble" is not exported but that is not the case. Any
> new use of that function?
> Joaquim
> From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Even Rouault
> Sent: Monday, October 19, 2020 3:31 PM
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] GDAL 3.1.4 RC1 available
> Hi,
> So that we can focus on 3.2.0 and onwards, I have prepared a GDAL/OGR 3.1.4
> release candidate, which should be the final one in the 3.1 series.
> Pick up an archive among the following ones (by ascending size):
> https://download.osgeo.org/gdal/3.1.4/gdal-3.1.4rc1.tar.xz
> https://download.osgeo.org/gdal/3.1.4/gdal-3.1.4rc1.tar.gz
> https://download.osgeo.org/gdal/3.1.4/gdal314rc1.zip
> A snapshot of the gdalautotest suite is also available :
> https://download.osgeo.org/gdal/3.1.4/gdalautotest-3.1.4rc1.tar.gz
> https://download.osgeo.org/gdal/3.1.4/gdalautotest-3.1.4rc1.zip
> GDAL-GRASS plugin:
> https://download.osgeo.org/gdal/3.1.4/gdal-grass-3.1.4.tar.gz
> The NEWS file is here :
> https://github.com/OSGeo/gdal/blob/v3.1.4RC1/gdal/NEWS
> I'll call for a vote promoting it to final soon if no serious problems are
> reported before.
> Best regards,
> Even
> Spatialys - Geospatial professional services http://www.spatialys.com
gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
