[gdal-dev] GDAL 3.1.4 RC1 available
Joaquim Manuel Freire Luís
jluis at ualg.pt
Tue Oct 20 04:27:13 PDT 2020
Even,
I don't think that was the case. I use a build system that resemble a bit homebrew. All packages are built in their own directories and SATAY there. Then I have a batch that creates symlinks do a directory that is the only in the computer path for my builds. So when I rebuild any package it gets automatically updated in my machine. Yes I did rebuild PROJ and GDAL from master as I always do and the problem arise but when I reverted PROJ to a commit only 9 days older (d1a0d95da549f7d32bcd8be408afe1fca62a6fb2), the problem disappeared.
-----Original Message-----
Sent: Tuesday, October 20, 2020 10:01 AM
To: Joaquim Manuel Freire Luís <jluis at ualg.pt>
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] GDAL 3.1.4 RC1 available
Joaquim,
Yes GDAL 3.1.4 makes use of the new function proj_crs_get_datum_ensemble() of PROJ master (tested by checking PROJ version number to be >= 7.2 since this is queued for the PROJ 7.2 release in a few days). So I suspect you might build GDAL against the header of a recent PROJ master, but at runtime use an older version of the .dll that has not the symbol
Even
> Reverting PROJ to
> (* Database query: add
> AuthorityFactory::ObjectType::DYNAMIC_GEODETIC_REFERENCE_FRAME and
> DYNAMIC_VERTICAL_REFERENCE_FRAME, and make corresponding C API work)
> Solved the issue.
> From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Joaquim
> Manuel Freire Luís
Sent: Monday, October 19, 2020 11:04 PM
> To: Even Rouault <even.rouault at spatialys.com>;
> Even,
> I'm puzzled with this but after updating and building GDAL+PROJ today
> (master) one of my MEX dlls that depend on GDAL and PROJ started to
> error with
> Invalid MEX-file
> 'C:\progs_cygw\GMTdev\gmt5\compileds\gmt6\VC14_64\bin\gmtmex.mexw64':
> The specified procedure could not be found.
> I managed to trace it to this likely source provided by
> DependencyWalker. I don't get it because it seems to indicate that
> "proj_crs_get_datum_ensemble" is not exported but that is not the
> case. Any new use of that function?
> Joaquim
> From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Even
> Rouault
> Sent: Monday, October 19, 2020 3:31 PM
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] GDAL 3.1.4 RC1 available
> Hi,
> So that we can focus on 3.2.0 and onwards, I have prepared a GDAL/OGR
> 3.1.4 release candidate, which should be the final one in the 3.1 series.
> Pick up an archive among the following ones (by ascending size):
> https://download.osgeo.org/gdal/3.1.4/gdal-3.1.4rc1.tar.xz
> https://download.osgeo.org/gdal/3.1.4/gdal-3.1.4rc1.tar.gz
> https://download.osgeo.org/gdal/3.1.4/gdal314rc1.zip
> A snapshot of the gdalautotest suite is also available :
> https://download.osgeo.org/gdal/3.1.4/gdalautotest-3.1.4rc1.tar.gz
> https://download.osgeo.org/gdal/3.1.4/gdalautotest-3.1.4rc1.zip
> GDAL-GRASS plugin:
> https://download.osgeo.org/gdal/3.1.4/gdal-grass-3.1.4.tar.gz
> The NEWS file is here :
> https://github.com/OSGeo/gdal/blob/v3.1.4RC1/gdal/NEWS
> I'll call for a vote promoting it to final soon if no serious problems
> are reported before.
> Best regards,
> Even
> Spatialys - Geospatial professional services http://www.spatialys.com
gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
