[gdal-dev] How to build GDAL 3.1.3 with sqlite3 3.33.0
Doug Niven
dniven at ucsc.edu
Mon Oct 19 19:34:14 PDT 2020
Hi Folks,
I’m having trouble building GDAL 3.1.3 with sqlite3 3.33.0 in Centos 7.
The compile steps work, but the build does not.
I believe this is because of conflicts between the built-in version of sqlite3 in Centos (3.7.17) and the newer one (3.33.0) I’ve built in /usr/local/ and /usr/local/lib
/usr/local/lib, where the sqlite3 library files are, is in my LD_LIBRARY_PATH
/usr/local/bin, where sqlite3 is, is also in my PATH
I’m curious how others have successfully managed to build GDAL with the above in mind.
I’d use the “amalgamated” sqlite3 if I could but need to build sqlite3 with ENABLE_COLUMN_METADATA for PostGIS to work.
Thanks in advance,
Doug
