[gdal-dev] 3.1.4 RC2 available [Re: GDAL 3.1.4 RC1 available]
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Oct 20 08:33:09 PDT 2020
On 2020-10-20 12:27 p.m., Alan Snow wrote:
> Hi Jeff,
> Sounds like you found the user writable directory in PROJ 7:
> https://proj.org/resource_files.html#where-are-proj-resource-files-looked-for
> https://proj.org/development/reference/functions.html#_CPPv440proj_context_get_user_writable_directoryP10PJ_CONTEXTi
> Hopefully the links are helpful,
> Alan
Thanks for the response Alan, yes that's exactly the documentation that
I have open here, for the user writeable directory in PROJ7, that I've
been following since the PROJ7 release. You can see there the mention
of the PROJ_LIB setting as well, I thought this was working with the
earlier PROJ7 release, but will do more testing, it could be that I
moved them from APPPDATA into PROJ_LIB after-the-fact. Will do more
testing...
-jeff
Jeff McKenna
MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
> On Tue, Oct 20, 2020, 10:18 AM Jeff McKenna
> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
> wrote:
> Hi Even,
> No issues here on Windows with RC2. More info:
> - MS4W build environment
> - VC 2017
> - proj-master, git-master, curl 7.73.0, sqlite 3.33.0, ...
> - no issues building GDAL 3.1.4 documentation with Sphinx 3.1.2
> (other than the usual Sphinx/Doxygen 26 warnings)
> - I just noticed that proj-master is no longer using my PROJ_LIB
> setting properly (instead with network=on the grids are downloaded into
> the obscure Windows user "AppData" directory....I'll definitely have to
> examine why...but that's for another list/day ha
> Thanks,
> -jeff
> Jeff McKenna
> On 2020-10-20 7:40 a.m., Even Rouault wrote:
> > Hi,
> > I've generated a RC2 that differs from RC1 with a single bug fix
> in configure
> > regarding Debian and CharLS 2.1 (see
> https://github.com/OSGeo/gdal/pull/3083)
> > https://download.osgeo.org/gdal/3.1.4/gdal-3.1.4rc2.tar.xz
> > https://download.osgeo.org/gdal/3.1.4/gdal-3.1.4rc2.tar.gz
> > https://download.osgeo.org/gdal/3.1.4/gdal314rc2.zip
> > Even
> >> Hi,
> >> So that we can focus on 3.2.0 and onwards, I have prepared a
> GDAL/OGR 3.1.4
> >> release candidate, which should be the final one in the 3.1 series.
> >> Pick up an archive among the following ones (by ascending size):
> >> https://download.osgeo.org/gdal/3.1.4/gdal-3.1.4rc1.tar.xz
> >> https://download.osgeo.org/gdal/3.1.4/gdal-3.1.4rc1.tar.gz
> >> https://download.osgeo.org/gdal/3.1.4/gdal314rc1.zip
> >> A snapshot of the gdalautotest suite is also available :
> >> https://download.osgeo.org/gdal/3.1.4/gdalautotest-3.1.4rc1.tar.gz
> >> https://download.osgeo.org/gdal/3.1.4/gdalautotest-3.1.4rc1.zip
> >> GDAL-GRASS plugin:
> >> https://download.osgeo.org/gdal/3.1.4/gdal-grass-3.1.4.tar.gz
> >> The NEWS file is here :
> >> https://github.com/OSGeo/gdal/blob/v3.1.4RC1/gdal/NEWS
> >> I'll call for a vote promoting it to final soon if no
> >> serious problems are reported before.
> >> Best regards,
> >> Even
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
