[gdal-dev] GDAL 3.1.4 RC1 available
Even Rouault
even.rouault at spatialys.com
Tue Oct 20 07:36:54 PDT 2020
On mardi 20 octobre 2020 14:30:28 CEST Joaquim Manuel Freire Luís wrote:
> Well,
> Mine also built correctly. It was on usage that the problem surfaced.
The windows CI build I mentionned also runs successfully GDAL autotest suite.
Even
> -----Original Message-----
> From: Even Rouault <even.rouault at spatialys.com>
> Sent: Tuesday, October 20, 2020 3:08 PM
> To: Joaquim Manuel Freire Luís <jluis at ualg.pt>
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] GDAL 3.1.4 RC1 available
> On mardi 20 octobre 2020 11:27:13 CEST Joaquim Manuel Freire Luís wrote:
> > Even,
> > I don't think that was the case. I use a build system that resemble a
> > bit homebrew. All packages are built in their own directories and SATAY
> > there. Then I have a batch that creates symlinks do a directory that is
> > the only in the computer path for my builds. So when I rebuild any
> > package it gets automatically updated in my machine. Yes I did rebuild
> > PROJ and GDAL from master as I always do and the problem arise but when I
> > reverted PROJ to a commit only 9 days older
> > (d1a0d95da549f7d32bcd8be408afe1fca62a6fb2), the problem disappeared.
> I have no explanation for your issue but
> https://github.com/rouault/gdal/runs/1280973974?check_suite_focus=true (
> https://github.com/rouault/gdal/blob/
> 424c570530bc9725cf7391d023ffbb72edf85ebb/.github/workflows/windows_build.yml
> ) is an example of a successful Windows build with both PROJ and GDAL
> masters.
> Even
> Spatialys - Geospatial professional services http://www.spatialys.com
