[gdal-dev] GDAL 3.1.4 RC1 available
Sean Gillies
sean at mapbox.com
Tue Oct 20 08:43:19 PDT 2020
Hi Even,
On Tue, Oct 20, 2020 at 3:01 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Joaquim,
> Yes GDAL 3.1.4 makes use of the new function proj_crs_get_datum_ensemble()
> of
> PROJ master (tested by checking PROJ version number to be >= 7.2 since
> this is
> queued for the PROJ 7.2 release in a few days). So I suspect you might
> build
> GDAL against the header of a recent PROJ master, but at runtime use an
> older
> version of the .dll that has not the symbol
> Even
Are you saying that GDAL 3.1.4 requires PROJ 7.2 or only that it uses the
PROJ 7.2 API when available? GDAL 3.1.3 works with PROJ 6.x and it would be
least surprising if GDAL 3.1.4 did as well.
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201020/83138f3f/attachment.html>
