[gdal-dev] How to build GDAL 3.1.3 with sqlite3 3.33.0
Doug Niven dniven at ucsc.edu
Tue Oct 20 08:11:02 PDT 2020
Well that was easy, thanks Mateusz!
I realize now what threw me off was seeing the following after running ‘configure’
  SQLite support:            yes
But the script was seeing the wrong sqlite3
Anyhow, I’m glad I asked the list, thanks again.
Doug
On Tue, 20 Oct 2020 at 04:34, Doug Niven <dniven at ucsc.edu <mailto:dniven at ucsc.edu>> wrote:
> I’m having trouble building GDAL 3.1.3 with sqlite3 3.33.0 in Centos 7.
> The compile steps work, but the build does not.
> I believe this is because of conflicts between the built-in version of sqlite3 in Centos (3.7.17) and the newer one (3.33.0) I’ve built in /usr/local/ and /usr/local/lib
> /usr/local/lib, where the sqlite3 library files are, is in my LD_LIBRARY_PATH
> /usr/local/bin, where sqlite3 is, is also in my PATH
> I’m curious how others have successfully managed to build GDAL with the above in mind.
As usual:
./configure --help
./configure --help | grep -i sqlite
So, you should be able to
./configure --with-sqlite3=/usr/local
as per
https://github.com/OSGeo/gdal/blob/master/gdal/m4/ax_lib_sqlite3.m4#L36-L37 <https://github.com/OSGeo/gdal/blob/master/gdal/m4/ax_lib_sqlite3.m4#L36-L37>
Best regards,
Mateusz Loskot, http://mateusz.loskot.net <http://mateusz.loskot.net/>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201020/fe785c30/attachment-0001.html>
