[gdal-dev] Compound CRS in shapefile
Javier Jimenez Shaw
j1 at jimenezshaw.com
Tue Oct 20 09:52:29 PDT 2020
Hi
When I create a 3D shapefile with GDAL, and I provide as SpatialReference a
compound CRS, it generates the prj file with the COMPD_CS syntax. Ok so far.
However, when I open the shapefile in QGIS, it does not recognize the CRS
at all (neither the horizontal part)
Is that intentional? QGIS is using GDAL to deal with shapefiles, afaik.
I could not find any reference to the prj in the shapefile documentation.
Thanks
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201020/a112f4a0/attachment.html>
