[gdal-dev] Compound CRS in shapefile
Even Rouault
even.rouault at spatialys.com
Tue Oct 20 10:24:41 PDT 2020
Javier,
> When I create a 3D shapefile with GDAL, and I provide as SpatialReference a
> compound CRS, it generates the prj file with the COMPD_CS syntax. Ok so far.
Always be specific: show the content of the .prj
> However, when I open the shapefile in QGIS, it does not recognize the CRS
> at all (neither the horizontal part)
What do you call "recognize" exactly: it doesn't find any CRS information, or
doesn't retrieve a EPSG code (retrieving a EPSG code from ESRI WKT is deeply
dark magic so doesn't always work) ?
> Is that intentional? QGIS is using GDAL to deal with shapefiles, afaik.
Probably for QGIS mailing list or tracker then.
I've tested the following:
ogr2ogr out.shp poly.shp -a_srs EPSG:7405
ogrinfo out.shp reports correctly a compoundCRS.
Opening that in QGIS + GDAL + PROJ master shows EPSG:27700 (the horizontal
part). Looking at QGIS QgsCoordinateReferenceSystem class, it only keeps the
horizontal part of a CompoundCRS. I guess mostly for compatibility reasons
with the rest of the code base.
Even
http://www.spatialys.com
