[gdal-dev] gdaladdo zoom level not supported
Even Rouault even.rouault at spatialys.com
Wed Oct 21 11:41:22 PDT 2020
> When I ran
> gdaladdo, I got an error message about zoom levels:
> ERROR 6: zoom_level > 22 not supported
You will get it also when doing "gdalinfo TLTR.mbtiles". There is a limitation
in the driver to zoom_level <= 22, because if the .mbtiles would have world
coverage, the dimensions would overflow a 32 bit signed integer as used by
GDAL. For a mbtiles with a smaller extent, that limitation could likely be
removed, but this is as things are currently in the driver.
But the issue here is that you're translating a tiff file in longlat to
mbtiles which expects EPSG:3857. So add an intermediate step
gdalwarp TLTR_crs.tif TLTR_crs_3857.tif -t_srs EPSG:3857
and then gdal_translate the result to mbtiles
And for your gdaladdo command just run
gdaladdo TLTR.mbtiles
It will automatically add the needed subsampling factors: 2, 4, 8, 16 etc..
I see you intend to pass zoom levels, but gdaladdo expects subsampling
factors, so 2^zoom_level.
http://www.spatialys.com
