[gdal-dev] Apply Vertical Grid Shift to coordinate
Matthias Kuhn
matthias at opengis.ch
Wed Oct 21 13:40:07 PDT 2020
Hi
I am trying to apply a vertical grid shift to a coordinate. I am
extrapolating from the example in the documentation at
https://proj.org/operations/transformations/vgridshift.html
The command I am entering is
echo 46.9480 7.4474 590 2020 | cct +proj=vgridshift
+grids=./geoid+HTRANS_ETRS2020.gtx
the result is:
46.9480000000 7.4474000000 -inf 2020.0000
I was hoping for the altitude being corrected by roughly 50 meters (instead
of being -inf).
The file geoid+HTRANS_ETRS2020.gtx is located in the current directory and
the coordinates should be within the applicable extent. 2020 was just a
random value (current year), but I guess it should not make any difference.
I guess it's just too late and I am missing something obvious. But if
someone could give me a hint to get me up and running, that would be great.
Thanks in advance
Matthias
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201021/e312bee4/attachment.html>
