[gdal-dev] Apply Vertical Grid Shift to coordinate
Even Rouault
even.rouault at spatialys.com
Thu Oct 22 01:41:34 PDT 2020
Hi Matthias,
(would be more a topic for proj mailing list)
> I am trying to apply a vertical grid shift to a coordinate. I am
> extrapolating from the example in the documentation at
> https://proj.org/operations/transformations/vgridshift.html
> The command I am entering is
> echo 46.9480 7.4474 590 2020 | cct +proj=vgridshift
> +grids=./geoid+HTRANS_ETRS2020.gtx
> the result is:
> 46.9480000000 7.4474000000 -inf 2020.0000
> I was hoping for the altitude being corrected by roughly 50 meters (instead
> of being -inf).
If the coordinate is located at Kornhausplatz in Bern, Switzerland, rather
than at Dollo in Ethiopia, you'd better switch your 2 first figures ;-)
When using PROJ pipelines, the coordinate order is longitude,latitude /
easting,northing , unless there are +proj=axisswap operations changing that.
When using higher level PROJ interfaces like cs2cs or projinfo with EPSG code,
then you'll have to comply with EPSG axis order.
Even
http://www.spatialys.com
