[gdal-dev] DLL load failed: The specified module could not be found
Arthur Morgan saadbaloch444 at gmail.com
Sat Oct 24 00:47:21 PDT 2020
Hello,
I have Anaconda latest 64-bit built on Windows 10, and the current
environment is running on Python 2.7. Now, I installed GDAL via conda
install -c conda-forge gdal
But when the script calls GDAL, it throws the following error:
  File "format_snow_params.py", line 20, in <module>
    from osgeo import gdal
  File
"D:\ProgramData\Anaconda3\envs\py2\lib\site-packages\osgeo\__init__.py",
line 25, in <module>
    _gdal = swig_import_helper()
  File
line 21, in swig_import_helper
    _mod = imp.load_module('_gdal', fp, pathname, description)
ImportError: DLL load failed: The specified module could not be found.
Please advise what to do?
Kind Regards,
Saad Baloch
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201024/6a73a9cb/attachment.html>
