[gdal-dev] DLL load failed: The specified module could not be found
Ivan Lucena
ivan.lucena at outlook.com
Sat Oct 24 08:09:48 PDT 2020
Hi Saad,
You probably have followed the steps to use Python2 on Anaconda3 [https://docs.anaconda.com/anaconda/user-guide/tasks/switch-environment/]
But did you install GDAL on both environments independently? Can you run "gdalinfo --version" while "py2" is activated?
We all know that DLL error messages are very misleading, "DLL load failed" might be related to a third part library. But that message doesn't seem to be 32/64 platform.
Worse thing you can do is to uninstall Anaconda3 to start fresh. The installer is not going to work.
Regards,
Ivan
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Arthur Morgan <saadbaloch444 at gmail.com>
Sent: Saturday, October 24, 2020 3:47 AM
To: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: [gdal-dev] DLL load failed: The specified module could not be found
Hello,
I have Anaconda latest 64-bit built on Windows 10, and the current environment is running on Python 2.7. Now, I installed GDAL via conda install -c conda-forge gdal
But when the script calls GDAL, it throws the following error:
File "format_snow_params.py", line 20, in <module>
from osgeo import gdal
File "D:\ProgramData\Anaconda3\envs\py2\lib\site-packages\osgeo\__init__.py", line 25, in <module>
_gdal = swig_import_helper()
File "D:\ProgramData\Anaconda3\envs\py2\lib\site-packages\osgeo\__init__.py", line 21, in swig_import_helper
_mod = imp.load_module('_gdal', fp, pathname, description)
ImportError: DLL load failed: The specified module could not be found.
Please advise what to do?
Kind Regards,
Saad Baloch
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201024/ef7f56de/attachment.html>
