[gdal-dev] Compiling GDAL with ArcSDE support
Johan Van de Wauw
johan.vandewauw at gmail.com
Wed Sep 2 06:39:00 PDT 2020
Marcin,
I managed to compile this extension against ubuntu 14.04 with at that time
gdal 1.10 , while helping a customer migrating away from arcSDE.
https://lists.osgeo.org/pipermail/gdal-dev/2016-November/045445.html
At that time, it was only possible to receive this client sdk on cdrom (!).
This was version 10.2, which I believe is the last version of ArcSDE. I
guess it will be much harder to get it now.
Are you sure you are still using arcsde?
Kind Regards,
Johan
On Tue, Sep 1, 2020 at 6:28 PM Marcin Grudzień <mgrudzien7 at gmail.com> wrote:
> Hi,
> I need to compile GDAL with the support of ESRI ArcSDE on Ubuntu 20.04. I
> already have some experience in compiling a custom version of GDAL. What I
> need is information what ESRI libraries I need to compile GDAL. My company
> uses ArcSDE (ArcGIS Server) in versions 10.3.1 and 10.6.1, the data is
> stored in Oracle and PostgreSQL databases.
> I have access to ESRI Maintenance Program, so I tried asking ESRI. They
> answered that they can’t help me, because they do not support the
> integration of their solutions with third-parties software.
> So again the question to you is what ESRI library I need to successfully
> integrate GDAL with ArcSDE? Where I can find it? I have access to the
> myESRI Platform from where I can download most of the ESRI products, but I
> do not know which of ESRI software packages contains drivers I need.
> Thank you in advance,
> Best regards,
> Marcin
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200902/56f63b74/attachment.html>
