[gdal-dev] Compiling GDAL with ArcSDE support
Marcin Grudzień
mgrudzien7 at gmail.com
Wed Sep 2 08:03:05 PDT 2020
Dear Johan,
Good question.
So let me explain the problem. My organization is using ESRI desktop clients (mainly ArcGIS Desktop) to upload the spatial data to the databases used across the organization and publish it via network services. As DBMSs, we use Oracle and Postgres. We upload the data using Esri clients in versions 10.3.1 or 1.6.1.
Now I need GDAL to do two things:
1. Export the data form these databases to other formats.
2. Use it to connect to MapServer to publish WMS, WFS services straight from databases.
So after looking through the documentation available online, I thought that using ArcSDE will be the best solution, but maybe there are better alternatives.
Best regards,
Marcin
> Wiadomość napisana przez Johan Van de Wauw <johan.vandewauw at gmail.com> w dniu 02.09.2020, o godz. 15:39:
> Marcin,
> I managed to compile this extension against ubuntu 14.04 with at that time gdal 1.10 , while helping a customer migrating away from arcSDE.
> https://lists.osgeo.org/pipermail/gdal-dev/2016-November/045445.html <https://lists.osgeo.org/pipermail/gdal-dev/2016-November/045445.html>
> At that time, it was only possible to receive this client sdk on cdrom (!). This was version 10.2, which I believe is the last version of ArcSDE. I guess it will be much harder to get it now.
> Are you sure you are still using arcsde?
> Kind Regards,
> Johan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200902/2510c695/attachment-0001.html>
