[gdal-dev] Compiling GDAL with ArcSDE support
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Sep 2 09:29:57 PDT 2020
Hi Marcin,
In the long run, I would go with PostGIS/PostgreSQL, and then display
directly in MapServer (as
https://mapserver.org/input/vector/postgis.html )  GDAL's related driver
page is full of interesting tips as well for PostGIS :
https://gdal.org/drivers/vector/pg.html
-jeff
Jeff McKenna
MapServer Consulting and Training Services
co-founder of FOSS4G
http://gatewaygeo.com/
On 2020-09-02 12:03 p.m., Marcin Grudzień wrote:
> Dear Johan,
> Good question.
> So let me explain the problem. My organization is using ESRI desktop
> clients (mainly ArcGIS Desktop) to upload the spatial data to the
> databases used across the organization and publish it via network
> services. As DBMSs, we use Oracle and Postgres. We upload the data using
> Esri clients in versions 10.3.1 or 1.6.1.
> Now I need GDAL to do two things:
> 1. Export the data form these databases to other formats.
> 2.  Use it to connect to MapServer to publish WMS, WFS services straight
> from databases.
> So after looking through the documentation available online, I thought
> that using ArcSDE will be the best solution, but maybe there are better
> alternatives.
> Best regards,
> Marcin
>> Wiadomość napisana przez Johan Van de Wauw <johan.vandewauw at gmail.com
>> <mailto:johan.vandewauw at gmail.com>> w dniu 02.09.2020, o godz. 15:39:
>> Marcin,
>> I managed to compile this extension against ubuntu 14.04 with at that
>> time gdal 1.10 , while helping a customer migrating away from arcSDE.
>> https://lists.osgeo.org/pipermail/gdal-dev/2016-November/045445.html
>> At that time, it was only possible to receive this client sdk on cdrom
>> (!). This was version 10.2, which I believe is the last version of
>> ArcSDE. I guess it will be much harder to get it now.
>> Are you sure you are still using arcsde?
>> Kind Regards,
>> Johan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
