[gdal-dev] Compiling GDAL with ArcSDE support
Howard Butler howard at hobu.co
Wed Sep 2 10:07:26 PDT 2020
Yes, both the vector and raster drivers should be dropped.  A determined person can get it from a previous release or git branch.
Howard
> On Sep 2, 2020, at 3:59 AM, Even Rouault <even.rouault at spatialys.com> wrote:
> Howard,
> Should we just remove the driver if it has become unusable ? People badly in need for it could still grab an older release.
> Even
> > > On Sep 1, 2020, at 11:27 AM, Marcin Grudzień <mgrudzien7 at gmail.com> wrote:
> > > Hi,
> > > I need to compile GDAL with the support of ESRI ArcSDE on Ubuntu 20.04. I
> > > already have some experience in compiling a custom version of GDAL. What
> > > I need is information what ESRI libraries I need to compile GDAL. My
> > > company uses ArcSDE (ArcGIS Server) in versions 10.3.1 and 10.6.1, the
> > > data is stored in Oracle and PostgreSQL databases.
> > > I have access to ESRI Maintenance Program, so I tried asking ESRI. They
> > > answered that they can’t help me, because they do not support the
> > > integration of their solutions with third-parties software.
> > > So again the question to you is what ESRI library I need to successfully
> > > integrate GDAL with ArcSDE? Where I can find it? I have access to the
> > > myESRI Platform from where I can download most of the ESRI products, but
> > > I do not know which of ESRI software packages contains drivers I need.
> > You need the ArcSDE Client SDK. I am doubtful you will find a copy that can
> > work on Ubuntu 20.04, however. It is my understanding that Esri stopped
> > distributing it multiple releases ago, and it is probable many changes have
> > happened to SDE's internals that could make a version of the Client SDK
> > fail to work even if you can find it.
> > Not-much-help'ly yours,
> > Howard
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
> Spatialys - Geospatial professional services
> http://www.spatialys.com <http://www.spatialys.com/>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200902/7544d54f/attachment-0001.html>
