[gdal-dev] Compiling GDAL with ArcSDE support
Even Rouault even.rouault at spatialys.com
Wed Sep 2 01:59:00 PDT 2020
Howard,
Should we just remove the driver if it has become unusable ? People badly in need for it could
still grab an older release.
Even
> > On Sep 1, 2020, at 11:27 AM, Marcin Grudzień <mgrudzien7 at gmail.com> wrote:
> > Hi,
> > I need to compile GDAL with the support of ESRI ArcSDE on Ubuntu 20.04. I
> > already have some experience in compiling a custom version of GDAL. What
> > I need is information what ESRI libraries I need to compile GDAL. My
> > company uses ArcSDE (ArcGIS Server) in versions 10.3.1 and 10.6.1, the
> > data is stored in Oracle and PostgreSQL databases.
> > I have access to ESRI Maintenance Program, so I tried asking ESRI. They
> > answered that they can’t help me, because they do not support the
> > integration of their solutions with third-parties software.
> > So again the question to you is what ESRI library I need to successfully
> > integrate GDAL with ArcSDE? Where I can find it? I have access to the
> > myESRI Platform from where I can download most of the ESRI products, but
> > I do not know which of ESRI software packages contains drivers I need.
> You need the ArcSDE Client SDK. I am doubtful you will find a copy that can
> work on Ubuntu 20.04, however. It is my understanding that Esri stopped
> distributing it multiple releases ago, and it is probable many changes have
> happened to SDE's internals that could make a version of the Client SDK
> fail to work even if you can find it.
> Not-much-help'ly yours,
> Howard
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200902/0bac618b/attachment.html>
