[gdal-dev] Compiling GDAL with ArcSDE support
    Andreas Oxenstierna
    ao at t-kartor.se
    Tue Sep  1 23:15:54 PDT 2020
Hi
Marcin, you have to solve it on the SQL level. I.e. use the
SQL-functions installed by ArcGIS Server to convert the ESRI geometries
to a GDAL readable geometry.
Deployed e.g. as database triggers whenever an ESRI geometry is updated.
I think the latest official SDK release is for 10.0:
https://support.esri.com/en/download/1877
>> On Sep 1, 2020, at 11:27 AM, Marcin Grudzień <mgrudzien7 at gmail.com> wrote:
>> Hi,
>> I need to compile GDAL with the support of ESRI ArcSDE on Ubuntu 20.04. I already have some experience in compiling a custom version of GDAL. What I need is information what ESRI libraries I need to compile GDAL. My company uses ArcSDE (ArcGIS Server) in versions 10.3.1 and 10.6.1, the data is stored in Oracle and PostgreSQL databases.
>> I have access to ESRI Maintenance Program, so I tried asking ESRI. They answered that they can’t help me, because they do not support the integration of their solutions with third-parties software.
>> So again the question to you is what ESRI library I need to successfully integrate GDAL with ArcSDE? Where I can find it? I have access to the myESRI Platform from where I can download most of the ESRI products, but I do not know which of ESRI software packages contains drivers I need.
> You need the ArcSDE Client SDK. I am doubtful you will find a copy that can work on Ubuntu 20.04, however. It is my understanding that Esri stopped distributing it multiple releases ago, and it is probable many changes have happened to SDE's internals that could make a version of the Client SDK fail to work even if you can find it.
> Not-much-help'ly yours,
> Howard
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Best Regards
Andreas Oxenstierna
T-Kartor Geospatial AB
Olof Mohlins väg 12 Kristianstad
mobile: +46 733 206831
mailto: ao at t-kartor.se
http://www.t-kartor.com
